0.1. Section Names An overview of section names and operation methods of the SILKYPIX® screen display will be explained. 0.1.1. Entire SILKYPIX Display ![]() The SILKYPIX® display is composed of the following elements.
The basic windows in this software are composed of the following parts.
Sub-controls for adjusting development parameters and windows for displaying status can be displayed as windows independent of the main window. These are collectively known as floating windows in this software.
These are windows that temporarily display various setting dialogs, setting changes, etc.
Message boxes are displayed while running the software in cases such as special processing, when an error occurs or when you are asked to select the next operation from multiple choices. Messages displayed here are assigned their own message numbers. Please make note of this message number if there is a problem, such as when an error occurs. You may be able to use the troubleshooting sections in the manual or on our company's home page. ![]() The Menu Bar is an interface from which you can select and execute various operations from the SILKYPIX menu. Sub-menus for each menu item are displayed in dropdown form when you click on an item from the Menu Bar. Each item on the Menu Bar is an entry point to locating menu items. They are categorized so that menu items are easy to find.
![]() Icons for functions that are frequently used are located in the toolbar.
This refers to the boxes to which controls can be located on either side of the Main Window. Each Information Box is divided into an upper and lower part. The "Navigator" and "Histogram" can be located in the upper part of the box. In addition, the "Folder", "Parameters controls" and "Image properties" can be located in the lower part of the box. ![]() "Parameters controls" refers to the entire box to which various controls for adjusting development parameters are located. You can locate multiple controls within the box, or combine each control and locate them on a tab page or in a control box. You can change the location of a control are performed from the Context Menu, displayed when you click ![]() Please see "0.1.7. How to Locate Controls" for details on how to change locations. The kinds of parts in the Main Control are classified into the following four parts. ![]() Sub-controls for adjusting development parameters are displayed on the tab page by default, or as a floating window, with each category prepared separately. (*1) 0.1.7. How to Locate Controls Sub-controls can be located in the control box. Selection / adjustment to parameters through sub-controls are mainly composed of controls for adjusting numerical values using sliders and edit boxes, dropdown lists and check boxes. Please see "0.1.8. How to Operate GUI" for operation methods.
![]() Located in the Main Control part, the six following sub-controls are displayed upon selecting the Category Selection Icon. Furthermore, these sub-controls are located on the tab page by default. ![]()
![]() Sub-controls that can be selected from the sub-control icons at the bottom of the Parameters controls are as indicated below. Controls displayed from the sub-control icons are displayed as a floating window by default. ![]()
![]() ![]() A context menu is displayed when you click on this menu, and you can change the location of controls from this menu. In addition, the method for locating controls that can be changed differs depending on the type of control. Please see "3.5. Arranging parameters controls and sub-controls" for details. Various GUI controls are located in parameters controls and sub-controls, but common methods of operation are explained here. ![]()
This is a SILKYPIX® JPEG Photography 8 standard GUI composed of slider bars, text boxes and buttons for changing numerical values. Use the following methods to change values.
Moving the focus to the text box will turn the background of the text box red. This indicates that you have entered direct editing of numerical values mode. Push the [Enter] key to confirm edited contents and leave the direct editing mode. Moving the focus to other controls will also allow you to confirm edited contents and leave the direct editing mode. Push the [Esc] key to delete edited contents and leave the direct editing mode. There are cases in which intermediate value settings cannot be set through other operation methods.
The mouse wheel can be used only when the mouse cursor is within a slider control composed of slider bars, edit boxes and buttons for changing numerical values. Except for direct editing modes in text boxes, the concept of focus was not adopted for "SILKYPIX® JPEG Photography 8", so please use the mouse wheel to move the mouse cursor on controls for operations.
This is a SILKYPIX® JPEG Photography 8 standard GUI composed of text boxes and buttons for changing numerical values. It is used in several sub-controls such as crop tool.
The mouse wheel can be used only when the mouse cursor is within an edit control composed of text boxes and buttons for changing numerical values. Except for direct editing modes in text boxes, the concept of focus was not adopted for "SILKYPIX® JPEG Photography 8", so please use the mouse wheel to move the mouse cursor on controls for operations.
A dropdown list will open when you click on the "V" mark to the right. Make your selection by moving the mouse and clicking on the selected item. You can change the selected item with the mouse when the dropdown list is not open.
You can turn these adjustments ON or OFF by clicking on them. 0.2. What is SILKYPIX® JPEG Photography? "SILKYPIX® JPEG Photography 8" has all of the features of the first choice photography software of professional photographers and enthusiasts "SILKYPIX® Developer Studio Pro 8"except is supports only the JPEG file format. SILKYPIX® JPEG Photography 8 does something like an "inverse transformation" from a JPEG image to a virtual RAW data (*1) and then treats them same as RAW data internally. (The function is "SILKYPIX® RAW Bridge.") Therefore, SILKYPIX® JPEG Photography 8 does the color processing which is more correct than photo retouching software can be done. *1 RAW data is the unprocessed data recorded as digital light energy information that image sensors capture. Compared to normal JPEG files, RAW files are bigger in size because native information is recorded at the time the photograph was taken. 0.2.1. Basic Image Adjustment Items In this software, you can adjust various parameters of development procedure. Basic development parameters will be introduced here.
0.3. Difference to Other Photo Retouching Software The development process with SILKYPIX® JPEG Photography 8 and image processing with a photo retouching software are similar. However, there is a critical difference between them. Therefore, we dare to use the word "development". Understanding of the difference helps you to use SILKYPIX® JPEG Photography 8 to its fullest. The important point is that this software always starts every image processing function based on the original JPEG data. When you change parameters in image processing (for example, changing "Exposure bias", "white balance" or "saturation"), the software always starts processing based on the original JPEG data. Development parameters are recorded in separate files different from the original JPEG data. Therefore, although the workload for the computer increases, you can obtain a lot of benefits described below.
Original image data is never changed, so you don't have to worry about losing it even if you make a wrong operation. The basic design of this software is to "not modify the original JPEG data files". If JPEG files recorded on a camera are processed with photo retouching software or digital camera editing software, there is a chance that the original image will be overwritten, but with this software the original data file is not modified. (*1)
In photo retouching software, images are processed through independent procedures, proceeding in order, one by one. For example, if you want to change brightness and then adjust color balance, you have to create the image with a new brightness level and then adjust color balance of the newly created picture image. Adjustment work proceeds while checking each result. If it is necessary to make minute adjustments to brightness after adjusting the color balance, then you have to choose to either start over again from the beginning or make the image at that time even brighter. Using the first method will not degrade the quality of the image, but it is that much more trouble. The second method is accompanied by image degradation. Always having to start over again is not actually realistic, and in most cases a certain degree of image degradation is allowed and work proceeds. The user's technique is shown in how he or she lessens degradation in image quality and adjusts the image to fit the purpose. With this software, image processing always takes place in the optimal order after reading the original JPEG data. If development parameters are determined, development results will be the same and there will be no degradation to image quality, whatever sequence is employed until adjustments are concluded. Whether you adjust the white balance after adjusting exposure or adjusting exposure after adjusting the white balance, if the final parameters are the same, the results will be the same. Therefore, you can change the parameters a number of times until you are satisfied with the result.
If you make adjustments through photo retouching software, the adjustment procedures will have an influence on image quality. You have to decide which one should be adjusted first, brightness or color balance. You also have to consider when you should adjust: Sharpening, Tone curve, and Color space for working or the Lens aberration controller. Always performing these in the optimal procedure demands a high degree of knowledge which to the lay person may result in excessive image quality deterioration. In addition, even if procedures are appropriate, there are times when gradation or a part of the color gamut is lost due to the combination of procedures. This software is designed so that image degradation like that through other photo retouching software will not occur, through internal processing that appropriately combines high-grade pipeline image processing that can transmit pixels brighter than pure white. Leave the image processing order up to SILKYPIX®. Whatever order the adjustments made to development parameter are performed, SILKYPIX® will output development results of the highest quality through optimal image processing.
Development parameters are automatically read and updated for each image, and are managed in a file separate from the original JPEG data. (*2)Therefore, you can later readjust development parameters from the previous adjustment results. Development parameters are also concealed in JPEG images that saved developments. The development parameters buried in these developments can be viewed with this software and applied to other images for processing. (*3) (*4) If you have the developed JPEG images and the original JPEG data, the development parameters for the development results can be read and minute adjustments can be made from the previous adjustment results at any time.
After image processing based on parameters that were set is complete, photo retouching software performs the next image processing, so image processing is complete at the stage when all adjustments have been completed. With this method, in order to go through multiple image processes, you must wait until the previous process is complete, which means that there is a lot of wait time until image processing is complete. With this software, development processing is gathered for later and can be processed as a batch. You can use a workflow in which development parameters are set while looking at a preview image and development processing is performed later in a batch. In order to efficiently adjust images, a preview image makes full use of simple image processing and partial development processing, and it is displayed quickly. Even if one image processing has not completely finished, there are many times when making the next adjustment to development parameters is possible, so less time is wasted waiting for the next development parameter to take effect. Even if a certain amount of time is necessary for actual development processing under the final development parameters, the work can be performed efficiently until the development parameters take effect. This workflow shows its power when processing large quantities of pictures at the same time.
Copyright (C) 2004-2019, Ichikawa Soft Laboratory Co.,Ltd. All rights reserved. |
