This will explain development processing of RAW data and JPEG / TIFF images, and how to save the results as JPEG and TIFF image files. There are two methods, "Develop", indicating development of one selected image, and "Batch develop", indicating development of multiple images at the same time.
[Processing format]
5.1. Develop This is a method for designating a way to save development processing and development results for selected single image. It processes following set instructions. You can select from two formats, a format for processing in real time and a format for registering jobs and processing in a batch. You can also register jobs for batch develop from "Develop" dialog, but compared to designating development with the "Batch develop" function, you can make more detailed settings and confirm development results in advance in the preview display. ![]() ![]() You can specify the filename to save the developed image, and specify settings for saving. You can switch between "Saved file" and "Settings" pages in the "Develop" dialog. When the "Saved file" tab is selected, you can designate the file folder, file name and file type for saving the development results. When the "Settings" tab is selected, you can make settings for develop while looking at the preview display of the development results. After confirming instructions for saving files and development settings, click on the "Develop" or "Batch develop" button and begin processing. ![]()
5.1.1. Saved File This page is for designating files to be saved. 5.1.2. Settings Select a location (= folder) for saving files and designate a file name for the file to be saved. Select the type of file, either a JPEG image (*.jpg) or TIFF image (*.tif). Please make detailed settings related to JPEG / TIFF images on the "Settings" page. If there are file names marked for a job registered for batch development in a location (= folder) for saving files, those file names are displayed as marked file names. When a file name marked here is designated, jobs registered for batch development are cancelled, and if that file already exists, it will be overwritten. This page is for making settings for develop while looking at the preview display of saved results. Settings here include many that have an influence on the developed image itself and on the quality of the image. Confirm appropriate development instructions while checking the effects and influence on the preview display. 5.1.2.1. Develop Taste You can select tastes prepared in advance from "Develop" tastes. It is advisable to register settings you often use as tastes. 5.1.2.2. Basic settings
Set the pixel size of the image to be saved. There are two ways to make designations, as follows.
When executing develop, you can specify the image size to save. In other words, you can save an enlarged or reduced image with this feature. You can select an image size from the history, which includes the original image size (100%), the previous size, and the size that has been used for this image and also for other images. It is convenient to select it from the history if you want to save it with the same size as the previous image. However, the list shows only the size which is matched to the aspect ratio of the target image. Click the initialize button to return to default values.
5.1.2.4. Preview Before saving an image, you can check it with the preview, which reflects the effect of the "unsharp mask" and "JPGE compression". When you adjust the setting value for the "unsharp mask" or the JPEG image, the preview is automatically refreshed. It takes a time to complete the development of the entire preview image. But when part of the image is displayed, only the part is developed, shortening the time for development. You can change a tool mode or a display magnification from the context menu, which is displayed by right-clicking on the preview image. 5.2. Batch develop ![]() A single process of developing and saving to a file a single image is called a "Job." When this job is registered in batch develop, batch development processes the registered jobs in the background. "Batch develop" develops in the background, so if jobs are registered, you do not have to wait for the processing to be completed, but rather you can immediately go to the next operation. If multiple images are being processed, "Jobs" for the number of images are prepared and these jobs are registered to batch development. They are processed in order. The following four methods are for performing batch develop.
This is a method for registering a currently selected image or multiple images to jobs in batch development. A dialog for making settings will be displayed. Select [Development (D)]-[Batch develop selected images] from the menu, or click on the icon in the toolbar to begin processing. The toolbar icons change based on the status of selected images. The ![]()
This is a method of registering images set with marks for development reservation to jobs in batch development. A dialog for making settings will be displayed. Select [Development (D)]-[Batch develop marked images (B)] from the menu, or click on the icon in the toolbar to begin processing. The toolbar icons change based on the status of selected images. The ![]()
This is a method for registering a currently selected image or multiple images to jobs in batch development. No dialog for making settings will be displayed. Current batch development settings will be used. Select [Development (D)]-[Immediately batch develop selected images] from the menu. This function is also assigned to the [F5] key by default.
This is a method for registering a currently selected image from "Develop" to jobs in batch development. Job registration is performed from the "Develop" dialog. When job registration is complete, the batch development processing dialog will close, even if development processing has not been completed. Registered jobs are processed in the background.Select [Development (D)]-[Develop (D)] from the menu, or click on the icon in the toolbar to begin processing. Jobs are registered to batch development by clicking on the "Batch develop" button in the "Develop" dialog. You can confirm the status of job processing at "Batch development status". The number of remaining jobs is also displayed on the batch development status icon on the right side of the toolbar. 5.2.1. Batch Develop Tastes "Batch Development Settings" can be chosen from tastes prepared in advance. It is advantageous to register settings used often as tastes. 5.2.2. Basic settings You can designate the type of file to be saved (JPEG or TIFF), pixel size of the image to be saved and development result save settings here. 5.2.3. Enhanced Settings "Development result save settings" and "Develop" have common setting methods. Please see "5.3.1.2. File output settings".
You can specify the size in pixels of each developed image when you want to save an enlarged image or reduced image. The following three methods are for designating.
The pixel size of the image to be saved will be the pixel size after cropping. The image is not enlarged or reduced. The cropping size is not designated, even if the output size is designated in the Crop tool.
If the output size is designated in the Crop tool, it is resized to the size designated for cropping. If cropping is not performed and if the output size is not designated in the Crop tool, a same size (100%) is recorded.
5.2.4. Other settings
You can save a developed image in the same folder as the original RAW image is stored.
You can create a sub-folder under the same folder as the original RAW image is stored.
Click [Select] button to display the "Select folder" dialog, and you can select the folder to save developed images.
Select an option for when there is a file of the same name as a file output to that destination. If you select "Overwrite", the existing file will be overwritten and lost. Please be extremely careful. ![]()
A different file name is automatically created and given to the file as RAW data.
A dialog box for confirming how to handle the file is displayed. Please decide the file name.
When the file name exists already, SILKYPIX® Developer Studio 6 overwrites the existing file automatically.
When the file name exists already, SILKYPIX® Developer Studio 6 skips saving the file. The file output in the above process is specified in detail at '5.3.1.2. File output settings'.The default naming conventions use the base name of the RAW data file for image processing as is, and convert and save with a JPG or TIF extension.
If you leave the check for 'Don't erase "Develop mark" after processing', the "Develop mark" will not be removed. If a mark for reserving development is being utilized as a mark for job registration, please remove the check. ![]() In order to check the batch development status, select [View (V)]-[Batch development status] from the menu or click on ![]() Switch and display two kinds of information by selecting tabs in the "Batch development status" sub-control. 5.2.5.1. Waiting Jobs currently under batch development and a list of jobs waiting to be processed are displayed. 5.2.5.2. Finished You can delete a selected job with the ![]() When you delete a job here, batch development for the deleted job will not be performed. This will display a list of completed batch development jobs. 5.2.5.3. Pausing and restarting batch development You can delete a selected job with the ![]() Jobs displayed here have already completed batch development processing, so deleting a job is only erases it from the displayed list so that it will not be seen. Jobs displayed here will accumulate and increase as batch development proceeds. Delete and arrange jobs when the number of jobs increases and the list becomes difficult to understand. A context menu will appear when you select a job and right click on it. By selecting "Open with Explorer (O)" after you select a job, you can open the developed and saved JPEG / TIFF image file in Explorer. You can also delete a selected job from the context menu. Batch development processing can be paused. All batch development will be halted by clicking on ![]() ![]() 5.3. Settings for development and saving Setting items common in both "Develop" and "Batch develop" are explained here. 5.3.1. Basic Settings Basic settings differ slightly between "Develop" and "Batch develop", but items that can be set in the same way will be explained. 5.3.2. Enhanced settings 5.3.1.1. File type for saving From the drop down list, you can select JPEG or TIFF file. When you want to set this in detail, use the "File output settings" dialog as described below. 5.3.1.2. File output settings By registering a setting status from "File output settings" that you often use as a taste, you can easily switch settings by selecting that taste. 5.3.1.3. Image size to save You can also set JPEG and TIFF saving formats here. There are many detailed setting items in "File output settings". Click on the "Setting details" button and open the "File output settings" dialog to make settings for all items. Please see "9.1. File output settings" for details. You can make detailed settings for both "JPEG" and "TIFF" by selecting "Type of saved file" here. Items that can be set here are the same as the items that can be set with "Setting details". Please see "9.1.2. Setting of File Type" for details. You can specify the size in pixels of each developed image when you want to save an enlarged image or reduced image. The methods for designating pixel size for resizing differ slightly between "Develop" and "Batch develop". You can record and save at an appropriate pixel size that meets the purposes of the image. ![]() You can designate a size for the image to be saved and make settings so that you save it resized to the pixel size you designated. Select "Fit to designated size" in "Image size to save". It will be saved at a pixel size within the restricted size that was designated. This setting method can be set for both "Develop" and "Batch develop". When creating the picture for a slide show that are displayed on a particular display, you can specify a display size. For example, when you want to display images on a VGA display, you can specify the display size of 640x480. By this setting, the developed image files are saved with the size of 640x480. Therefore, you do not need to adjust the image size at the slide show. [Adjust orientation of the above rectangle to the target aspect ratio] When you check this setting, the specified size is automatically adjusted to match the orientation with the aspect ratio of the target image. For example, when specifying 640x480 as size, the result size will be inscribed to 640x480 for the lateral image and it will be inscribed to 480x640 for the longitudinal image. Settings for imprint data and unsharp mask are made here. ![]() As the name of the function implies, "Imprint data" allows you to imprint the date and time the photograph was taken onto the development results. 5.3.2.2. Unsharp mask In addition to the date and time the photograph was taken, you can also include image information, optional characters and credit images on the development results. You can imprint the date and time the photograph was taken and image information by selecting prepared data for imprint data. You cannot imprint the date if the developed file is a 16bit TIFF. Creating "Imprint data" is required for imprinting a credit image you prepared Only JPEG images and TIFF images can be selected as images to be imprinted. Semitransparent images are also compatible with imprinting because it is compatible with TIFF with transparent color information.
![]() In addition to the sharpness set as a development parameter, use this when you want to add more sharpness in accordance with your purpose and output format for the development results. Please use this feature according to your purpose and the output type, apart from the sharpness specified by the development parameter. The "sharpening" specified by the development parameter should be used for each image to adjust resolution. The other hand, the "unsharp mask filter" should be used for a certain purpose and the output type. For example, when you want to reduce an image for using on a website, you can use the unsharp mask to make up for the sharpness of the image, which will be lost by the image reduction. Or when you want to prepare an image for printing, you can use the unsharp mask to increase image sharpness, avoiding blurred prints. Please refer to '10.1.9. Proper Use of Sharp in Development Parameters and Unsharp Mask when Developing / Printing' for more details. 5.3.2.2.1. Amount You can specify the "amount" when you use the "unsharp mask". The larger the value is, the stronger the sharpness is. 5.3.2.2.2. Radius Radius sets the width of edge of the object to be emphasized. The larger the value is, the wider the edge is (stronger sharpness), and the smaller the value is, the narrower the edge is (weaker sharpness). Typically, setting the range between 0.5-1.0 is recommended. 5.3.2.2.3. Threshold If the value is set smaller, sharpness is emphasized regardless of the clearness of the edges of objects. If the value is set larger, sharpness is emphasized only where the edges of objects are clearer to some degree. You can prevent noise in an image with this parameter, typically, when it is set to '1'. Please adjust this parameter to balance noise and sharpness. |
