0.1. Section Names An overview of section names and operation methods of the SILKYPIX® screen display will be explained. 0.1.1. Entire SILKYPIX Display ![]() The SILKYPIX® display is composed of the following elements.
The basic windows in this software are composed of the following parts.
Sub-controls for adjusting development parameters and windows for displaying status can be displayed as windows independent of the main window. These are collectively known as floating windows in this software.
These are windows that temporarily display various setting dialogs, setting changes, etc.
Message boxes are displayed while running the software in cases such as special processing, when an error occurs or when you are asked to select the next operation from multiple choices. Messages displayed here are assigned their own message numbers. Please make note of this message number if there is a problem, such as when an error occurs. You may be able to use the troubleshooting sections in the manual or on our company's home page. The Menu Bar is an interface from which you can select and execute various operations from the SILKYPIX menu. Sub-menus for each menu item are displayed in dropdown form when you click on an item from the Menu Bar. Each item on the Menu Bar is an entry point to locating menu items. They are categorized so that menu items are easy to find.
![]() Icons for functions that are frequently used are located in the toolbar.
This refers to the boxes to which controls can be located on either side of the Main Window. Each Information Box is divided into an upper and lower part. The "Navigator" and "Histogram" can be located in the upper part of the box. In addition, the "Folder", "Parameters controls" and "Image properties" can be located in the lower part of the box. 0.1.5. Parameters Controls "Parameters controls" refers to the entire box to which various controls for adjusting development parameters are located. You can locate multiple controls within the box, or combine each control and locate them on a tab page or in a control box. You can change the location of a control are performed from the Context Menu, displayed when you click on the upper right of the controls.Please see "0.1.7. How to Locate Controls" for details on how to change locations. The kinds of parts in the Main Control are classified into the following four parts. 0.1.6. Sub-controls for adjusting development parameters and windows for displaying status can be displayed as windows independent of the main window. Sub-controls for adjusting development parameters are displayed on the tab page by default, or as a floating window, with each category prepared separately. (*1) 0.1.7. How to Locate Controls Sub-controls can be located in the control box. Selection / adjustment to parameters through sub-controls are mainly composed of controls for adjusting numerical values using sliders and edit boxes, dropdown lists and check boxes. Please see "0.1.8. How to Operate GUI" for operation methods.
0.1.6.1. Category Selection Icons Located in the Main Control part, the six following sub-controls are displayed upon selecting the Category Selection Icon. 0.1.6.2. Sub-control icons Furthermore, these sub-controls are located on the tab page by default.
Sub-controls that can be selected from the sub-control icons at the bottom of the Parameters controls are as indicated below. Controls displayed from the sub-control icons are displayed as a floating window by default. ![]()
A icon is displayed to the upper right of most controls, such as Parameters controls and Sub-controls.A context menu is displayed when you click on this menu, and you can change the location of controls from this menu. In addition, the method for locating controls that can be changed differs depending on the type of control. Please see "3.5. Arranging parameters controls and sub-controls" for details. Various GUI controls are located in parameters controls and sub-controls, but common methods of operation are explained here.
This is a SILKYPIX® Developer Studio Pro 6 standard GUI composed of slider bars, text boxes and buttons for changing numerical values. Use the following methods to change values.
Moving the focus to the text box will turn the background of the text box red. This indicates that you have entered direct editing of numerical values mode. Push the [Enter] key to confirm edited contents and leave the direct editing mode. Moving the focus to other controls will also allow you to confirm edited contents and leave the direct editing mode. Push the [Esc] key to delete edited contents and leave the direct editing mode. There are cases in which intermediate value settings cannot be set through other operation methods.
The mouse wheel can be used only when the mouse cursor is within a slider control composed of slider bars, edit boxes and buttons for changing numerical values. Except for direct editing modes in text boxes, the concept of focus was not adopted for "SILKYPIX® Developer Studio Pro 6", so please use the mouse wheel to move the mouse cursor on controls for operations.
This is a SILKYPIX® Developer Studio Pro 6 standard GUI composed of text boxes and buttons for changing numerical values. It is used in several sub-controls such as crop tool.
The mouse wheel can be used only when the mouse cursor is within an edit control composed of text boxes and buttons for changing numerical values. Except for direct editing modes in text boxes, the concept of focus was not adopted for "SILKYPIX® Developer Studio Pro 6", so please use the mouse wheel to move the mouse cursor on controls for operations.
A dropdown list will open when you click on the "V" mark to the right. Make your selection by moving the mouse and clicking on the selected item. You can change the selected item with the mouse when the dropdown list is not open.
You can turn these adjustments ON or OFF by clicking on them. 0.2. What is SILKYPIX®? This SILKYPIX® software generates images by processing RAW data recorded by the digital camera.(*1) This process of generating an image by processing RAW data is called "development". RAW data is the unprocessed data recorded as digital light energy information that image sensors capture. Compared to normal JPEG files, RAW files are bigger in size because native information is recorded at the time the photograph was taken. When photographs are taken in RAW e.g. when photographs are saved as RAW data, you will be able to perform more varied image processing from the unprocessed light energy information even after taking the photograph. The role of SILKYPIX® is to get the most out of the photographic merits of RAW and to draw out as much image information as possible when reproducing scenes shot in RAW data. SILKYPIX® was developed to make this a reality. *1 ... JPEG/TIFF files can be developed. For more details, please refer to '2.4. How to Handle JPEG/TIFF Image'. 0.2.1. Basic Image Adjustment Items In this software, you can adjust various parameters of development procedure. Basic development parameters will be introduced here. 0.2.2. Features of SILKYPIX®
When you store image data as RAW data and use this software to develop them, you don't have to worry much about adjustments during taking the picture because you can do most corrections at the development process stage. The merits of recording and saving to RAW data compared with saving in JPEG / TIFF are that information is not processed and the amount of information recorded is much richer. It is also possible to readjust photographs recorded and saved as JPEG / TIFF with this software. However, compared to RAW data, there is less information recorded because JPEG / TIFF images convert to a special color space (sRGB, Adobe RGB, etc.) and color gradation converts to 8bit = 256 steps. Therefore, if you readjust photographs saved as JPEG / TIFF, the breadth of adjustments are narrowed and deterioration of the image from the adjustments becomes greater. In order to adjust images while maintaining high image quality, it is necessary to save the RAW data when taking the photograph. By saving to RAW data and developing with this software, you will be able to obtain very similar results when developing after taking the photograph, as when color and image quality are adjusted at the time the photograph was taken. SILKYPIX® greatly shortens the time spent shooting and increases the chance of capturing that important "moment" on the camera. In addition, with the adoption of a high development algorithm, SILKYPIX® has the following features.
Although it is generally considered that resolution is decided by the type of lens and the number of pixels of the image sensor, a key factor of actual image resolution is the demosaic process during development procedure. When you select RAW data to record images and use SILKYPIX® Developer Studio Pro 6 to develop them, you can obtain higher quality pictures than the JPEG image which the camera records in taking a photograph.
When photographing with a digital camera, the color boundary in high saturation area is lost and becomes white outline, which is a specific phenomena of digital cameras. This effect called digital haloing is caused by the white outline through the phenomena that occurs when color resolution is low compared to excessive brightness. We have therefore created a completely new demosaicing logic and embedded it into the software in order to provide advanced color resolution. This logic allows delicate and advanced color resolution.
Most of digital cameras now have sensors with a structure called Bayer array. The R, G, and B sensor elements are allocated in order of Bayer array flatly. Each sensor can only capture one of the R, B or G, so false color appears on the edge of picture or area including delicate pattern. The software reduces this false colors highly effectively with advanced pixel value forecast logic. Fundamentally, high resolution, high separation capability, and false color reduction are not realized at the same time logically. High resolution causes increased false color phenomenon, and a trail of false color reduction results in low resolution. However, the software efficiently enables the realization of these processes simultaneously to create natural pictures and colors.
When photographing in high sensitivity mode for night photography or in a dark place, noise of the image sensor generates color noise spots on the image, which is specific to digital cameras. These color noise spots appearing irregularly on the picture are very unpleasant to the eyes, and supposedly many photographers avoid high sensitive photography because of this phenomenon. The software provides a function for reducing the color noise that surprisingly creates clean pictures for high sensitive photography. With this software, you can select a wide variety of photographic methods and objects to create a new photograph.
The software has the function to reduce color reverse or overexposure (bleached-out looking) in the highlight area. For example, when taking a picture of a person, if you increase a development gain to make a skin color white, color shift phenomenon occurs and highlight boundary area often becomes yellow. The Highlight controller of the software enables color control in over exposed area and creates fine color adjustment in these highlight areas.
In order to create accurate colors with various types of light sources, we have embedded our unique color matching logic based on multiple color matching data acquired in many test pictures. Many types of light source with various spectral distributions, such as sunlight (natural light), fluorescent light, tungsten filament lamp, glow of sunset, electric flash and combination of them are supported, which realizes accurate color reproducibility. Based on this color reproduction, you can utilize "3-dimensional color mapping methods", which converts colors into 3-dimentional data to create (Memory color) expressing similar colors with the colors in a human's memory, (Portrait color), expressing highlights of the skin, and Film taste expressing colors in a positive (Film color)". You can use these color modes according to its utilization or picture image. Also, '4.10. Fine Color Controller' can change the precise color and to control the delicate color.
The "dynamic range" control function allows you to make the best use of RAW's ability, which has enough "dynamic range" and records whiter energy than the white point. You can obtain the smooth gradation in highlight area similar to film. 0.3. Difference to Other Photo Retouching Software RAW development process with SILKYPIX® Developer Studio Pro 6 and image processing with a photo retouching software are similar. While various types of photo retouching software that support RAW data are increasingly available in the market, there is a critical difference between them. Understanding of the difference helps you to use SILKYPIX® Developer Studio Pro 6 to its fullest. The important point is that this software always starts every image processing function based on RAW data. When you change parameters in image processing (for example, changing "Exposure bias", "white balance" or "saturation"), the software always starts processing based on RAW data. Development parameters are recorded in separate files different from RAW data. Therefore, although the workload for the computer increases, you can obtain a lot of benefits described below.
Original image data is never changed, so you don't have to worry about losing it even if you make a wrong operation. The basic design of this software is to "not modify RAW data files". If JPEG files recorded on a camera are processed with photo retouching software or digital camera editing software, there is a chance that the original image will be overwritten, but with this software the original data file is not modified. (*1)
In photo retouching software, images are processed through independent procedures, proceeding in order, one by one. For example, if you want to change brightness and then adjust color balance, you have to create the image with a new brightness level and then adjust color balance of the newly created picture image. Adjustment work proceeds while checking each result. If it is necessary to make minute adjustments to brightness after adjusting the color balance, then you have to choose to either start over again from the beginning or make the image at that time even brighter. Using the first method will not degrade the quality of the image, but it is that much more trouble. The second method is accompanied by image degradation. Always having to start over again is not actually realistic, and in most cases a certain degree of image degradation is allowed and work proceeds. The user's technique is shown in how he or she lessens degradation in image quality and adjusts the image to fit the purpose. With this software, image processing always takes place in the optimal order after reading the RAW data. If development parameters are determined, development results will be the same and there will be no degradation to image quality, whatever sequence is employed until adjustments are concluded. Whether you adjust the white balance after adjusting exposure or adjusting exposure after adjusting the white balance, if the final parameters are the same, the results will be the same. Therefore, you can change the parameters a number of times until you are satisfied with the result.
If you make adjustments through photo retouching software, the adjustment procedures will have an influence on image quality. You have to decide which one should be adjusted first, brightness or color balance. You also have to consider when you should adjust: Sharpening, Tone curve, and Color space for working or the Lens aberration controller. Always performing these in the optimal procedure demands a high degree of knowledge which to the lay person may result in excessive image quality deterioration. In addition, even if procedures are appropriate, there are times when gradation or a part of the color gamut is lost due to the combination of procedures. This software is designed so that image degradation like that through other photo retouching software will not occur, through internal processing that appropriately combines high-grade pipeline image processing that can transmit pixels brighter than pure white. Leave the image processing order up to SILKYPIX®. Whatever order the adjustments made to development parameter are performed, SILKYPIX® will output development results of the highest quality through optimal image processing.
Development parameters are automatically read and updated for each image, and are managed in a file separate from the RAW data. (*2)Therefore, you can later readjust development parameters from the previous adjustment results. Development parameters are also concealed in JPEG / TIFF images that saved developments. The development parameters buried in these developments can be viewed with this software and applied to other images for processing. (*3) (*4) If you have the developed JPEG / TIFF images and the original RAW data, the development parameters for the development results can be read and minute adjustments can be made from the previous adjustment results at any time.
After image processing based on parameters that were set is complete, photo retouching software performs the next image processing, so image processing is complete at the stage when all adjustments have been completed. With this method, in order to go through multiple image processes, you must wait until the previous process is complete, which means that there is a lot of wait time until image processing is complete. With this software, development processing is gathered for later and can be processed as a batch. You can use a workflow in which development parameters are set while looking at a preview image and development processing is performed later in a batch. In order to efficiently adjust images, a preview image makes full use of simple image processing and partial development processing, and it is displayed quickly. Even if one image processing has not completely finished, there are many times when making the next adjustment to development parameters is possible, so less time is wasted waiting for the next development parameter to take effect. Even if a certain amount of time is necessary for actual development processing under the final development parameters, the work can be performed efficiently until the development parameters take effect. This workflow shows its power when processing large quantities of pictures at the same time.
0.4. Differences with conventional products The following is an explanation of functions that have been added / modified since "SILKYPIX® Developer Studio Pro 5". 0.4.1. Development processing / Output processing Improved Image Quality with Noise Reduction 0.4.2. Displays With further improved noise reduction, it is possible to reduce noise while retaining high-frequency components (parts with large changes in brightness), even in photographs taken with a high ISO film speed. Separating Dodge / HDR Highlight ShadowsIn addition, color omissions and leakage that occurred when performing color distortion for reducing color noise have been alleviated compared to prior processing. This will expand your photography. Conventionally, tone adjustments to dark and light portions have been made simultaneously, but it is now possible to adjust light portions and dark portions independently with the dodge and HDR functions. Red Eye CorrectionsUsing the "Red eye correction" mode within the Spotting tools, it is possible to designate portions to correct for red eyes from flashes. Portrait beautificationYou can control details such as chapping and keratin on the skin through automatically searching and smoothing out expressions of portions that resemble skin tones. Add NoiseNatural, high resolution processing on skin tones and other boundary portions has become possible. By adding some gray scale noise to a photograph, you can obtain the effect of emphasizing details of the subject and increasing the feeling of sharpness. Automatic Level CorrectionThis does not simply add noise uniformly, but rather distinguishes the brightness of the photograph and automatically changes the amount of noise depending on the area, becoming a filter to add noise as applicable to the photograph. Therefore, it can also be used to emulate film grain (the granular feeling of film). This is a function that automatically recognizes the histogram of the photograph and automatically sets the levels for shadows and highlights. It is a convenient function for setting a tone which utilizes RGB tones to the maximum when the lighting conditions of photographs are faint (low contrast). Addition of "Unsharp Mask" to Types of SharpeningWhen there are strong level corrections, the contrast may become high so that it looks as if the chroma has been raised. When this happens, lower the chroma using the Chroma Slider. The amount of correction can be adjusted separately for shadows and highlights. There is an item for adjusting the amount of correction in the "Function settings". Since the shadows and highlights can be adjusted separately, it is also possible to automatically correct only for shadows or for highlighting. Unsharp mask was added to the types of Sharpening. Shading Center ToolThis unsharp mask processes color spaces uniquely defined by our company, and can add sharpness while controlling the coloring of outlines. The center of corrections to shading (peripheral dimming) can be changed. Soft ProofingThis is particularly effective for obtaining dimming effects equally in the four corners when you crop the photograph and the angle of view is moved from the center. This is a mode that displays changes in color conversion processing from color profiles on the preview window to be printed on a printer. Hot FolderYou can check the color taste on the preview window as if printed using "Printer + Paper" by selecting a color profile. Particularly when using fine art paper that has greatly different RGB characteristics, it is possible to edit data for printing with high precision because you can check color shifts and degradation (or rising) of dark areas. This function makes corrections (simulations) with high reliability only on environments in which color management has been performed on a monitor on which print monitoring has been arranged. This function monitors a selected folder and if there is any added data, automatically reads it to SILKYPIX®. It can also be applied when reading if it is a previously registered development parameter. It allows for joint displays of previews in real time when you perform tether photography such as with camera controls on your camera. * This does not work when sub-folders are designated or multiple folders are selected. Navigator You can check the preview area on special thumbnails or perform operations. Information BoxWhen the preview window is magnified beyond the fitted display, a guide can be displayed with special thumbnails on places displayed on the preview window. You can change the location of the preview screen by clicking on the Navigator or dragging the guide. An Information Box has been added to allow you to locate controls to either side of the Main Window. Improvement to set/clear marksThis makes a layout with three divided screens possible. You can efficiently use the size of the screen, such as when using a wide LCD monitor. In addition, because you can locate the controls to either side, you can locate them the same way as in past versions by bringing them together into one. It has become possible to set marks (such as User marks and develop mark) on the status bar. Full Screen PreviewYou can easily check the overall ambience of a photograph by using full screen display. Applying Spoit Tools to Reference Preview / ThumbnailIn addition, if you have a multiple monitor environment (two or more monitors), the Main Window and the Preview can be displayed on separate monitors in full screen display. While displaying the photograph in full screen on the main monitor, you can locate the controls on the sub-monitor and perform editing operations. You can designate tools designated for spoiting, such as exposure bias tool, gray balance tool and black level tool, on the reference preview and thumbnail screen. AVX2 SupportDesignations from conditions with different parameters and corrections from different image information are also possible. The computation speed for some image processing has been improved through supporting the AVX2 instruction set, which is available on PC that are equipped with the fourth generation and beyond Intel® Core™ processors. Separate Displays of JPEG/TIFF with the Same NameWith the addition of "Treat files with the same name as a group" in the function settings, JPEG/TIFF with the same name as RAW data can be displayed separately without treating them as a group. This is useful for comparing RAW data and JPEG/TIFF that was recorded at the same time. Batch Editing of Multiple ImagesIt has become possible to edit parameters as a batch when multiple images are selected from the thumbnails. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
