SILKYPIX Developer Studio Pro10 / 10 English Software Manual
Copyright © 2004-2020, Ichikawa Soft Laboratory Co.,Ltd. All rights reserved.
Thank you very much for using SILKYPIX Developer Studio Pro10 / 10.
[SILKYPIX Developer Studio] was developed to expand the limits in quality of digital images by using a highly advanced raw engine – helping the user of Digital SLRs to get the most out of every picture taken and providing an easy way to control the path from the picture to the image.
This manual is a common software manual of “SILKYPIX Developer Studio Pro10” and “SILKYPIX Developer Studio 10”.
As for the contents described in this manual, there is no difference depending on the version in function, usage, set value etc. unless there is a special notation.
In this manual, the software is shown with the following icons for explanation targeting only “SILKYPIX Developer Studio Pro10”.
Contents
- 0. Overview and Introduction
- 1. Startup
- 2. Designating image files for processing
- 3. Display modes
- 3.1. Switching Display Modes
- 3.2. Preview window
- 3.3. Thumbnail window
- 3.4. Operations for selected images
- 3.5. Arranging parameters controls and sub-controls
- 3.6. Toolbar position
- 3.7. Turning floating window display on / off
- 3.8. Icons that show status of image
- 4. How to Adjust Development Parameter
- 4.1. “Parameters Controls” and “Sub-control”
- 4.2. Sub-control
- 4.3. Exposure / Luminance
- 4.4. White Balance
- 4.4.1. Adjusting White Balance with Taste
- 4.4.2. Auto White Balance
- 4.4.3. Color Temperature and Color Deflection
- 4.4.4. Gray balance tool
- 4.4.5. Skin color tool
- 4.4.6. Gray balance tool for underwater photo
- 4.4.7. Dark Adjustment
- 4.4.8. Multi-light source compensation
- 4.4.9. White Balance Adjustment
- 4.4.10. Summary of Color and Adjustment
- 4.5. Tone
- 4.6. Color Adjustment
- 4.7. Sharpening / Noise Reduction
- 4.8. Development settings
- 4.9. Highlight controller
- 4.10. Fine Color Controller
- 4.11. Lens Aberration Controller
- 4.12. Rotation/Shift lens effect
- 4.13. Effects
- 4.14. Crop tool
- 4.15. Monochrome controller
- 4.16. Underwater photo controller
- 4.17. Spotting tools
- 4.18. Partial correction tool
- 4.19. Editing history
- 4.20. Image properties
- 4.21. Other
- 5. Saving Development Process and Development Results
- 6. Useful Functions for Adjustment
- 7. Development Parameter Operation
- 7.1. Copy development parameters
- 7.2. Save Development Parameters
- 7.3. Load Development Parameters
- 7.4. Initialize Development Parameters
- 7.5. Copy Development Parameters to Storerooms
- 7.6. Set Development Parameters to Multiple Images
- 7.7. Operations for Multiple Selected Images
- 7.8. Select Taste
- 7.9. Add taste
- 7.10. Default parameters settings
- 7.11. About “SILKYPIX Developer Studio Pro10” Development Parameters
- 8. File Operation and Printing
- 8.1. Delete Procedures
- 8.2. Copy/Move Procedures
- 8.3. Files to be Deleted, Copied, or Moved
- 8.4. Rename/Batch rename
- 8.5. Printing
- 8.6. Plug-ins
- 8.7. Open with another application
- 9. Option and Setting
- 9.1. File output settings
- 9.2. Display settings
- 9.2.1. Color management
- 9.2.2. Thumbnail window
- 9.2.3. Preview window
- 9.2.3.1. Preview rendering method
- 9.2.3.2. When double-clicking on preview window
- 9.2.3.3. Grid Settings
- 9.2.3.4. Partial Correction Tool Settings
- 9.2.3.5. Opening a folder in preview mode
- 9.2.3.6. Background colors
- 9.2.3.7. Blink preview frame during preview rendering
- 9.2.3.8. Insert margins for “Fitted display” / “Whole display”
- 9.2.4. Others
- 9.3. Function settings
- 9.3.1. Functions
- 9.3.1.1. When a JPEG/TIFF/DNG image is rotated
- 9.3.1.2. Luminance level of exp. bias tool
- 9.3.1.3. Luminance level of the black level tool
- 9.3.1.4. Threshold of highlight warning
- 9.3.1.5. Threshold of shadow warning
- 9.3.1.6. Threshold of focus peaking
- 9.3.1.7. Set automatic level correction
- 9.3.1.8. Tooltip
- 9.3.1.9. Handle only RAW images
- 9.3.1.10. Develop JPEG/TIFF images
- 9.3.1.11. Treat the same base name (file name without extension) files as a single image
- 9.3.1.12. Open last accessed folder when starting
- 9.3.1.13. Create data file for the lens profile
- 9.3.2. Operations
- 9.3.3. Performance
- 9.3.1. Functions
- 9.4. Shortcut keys settings
- 9.5. Default parameters settings
- 9.6. Customize toolbar
- 9.7. Imprint data settings
- 9.8. Import and export settings
- 9.9. Options
- 9.10. Troubleshooting settings
- 10. How to Handle SILKYPIX Perfectly
- 10.1. Techniques
- 10.1.1. Speed up Refreshing of Preview
- 10.1.2. Utilizing Difference between Exposure Biases of Camera and SILKYPIX
- 10.1.3. Utilizing Difference between ISO Speed Adjustment of Camera and Exposure Bias of SILKYPIX
- 10.1.4. Relationship between Demosaicing Sharpness and Picture Quality
- 10.1.5. Adjustment for Over-saturation
- 10.1.6. Color Gamut and Adjustment Outside of Color Gamut
- 10.1.7. Sharpening Image
- 10.1.8. How to Take Advantage of Dynamic Range
- 10.1.9. Proper Use of Sharp in Development Parameters and Unsharp Mask when Developing / Printing
- 10.2. Photographic Techniques
- 10.3. Advanced Techniques
- 10.4. Knowledge
- 10.4.1. Color Temperature and Color Deflection
- 10.4.2. Exif Information
- 10.4.3. Files Created Automatically
- 10.4.4. DNG (Digital Negative) format compatibility
- 10.4.5. Color management
- 10.4.5.1. What is color management?
- 10.4.5.2. Color space and color profile
- 10.4.5.3. Color management performed on SILKYPIX
- 10.4.5.4. Color management on monitor displays
- 10.4.5.5. Color management for print output
- 10.4.5.6. Restrictions to color management
- 10.4.5.7. “sRGB” vs “Adobe RGB”
- 10.4.5.8. Troubleshooting
- 10.4.6. Thermal Runaway
- 10.1. Techniques
- 11. Troubleshooting
- 12. License Agreement
- Please acknowledge that the contents and price of the specific software and manual of this product will change without notice.
- The specifications and the screen shots that have been described in this manual might be different from the product version.
- This manual has been copyrighted. It is prohibited to reproduce, reprint any of the materials and product without obtaining permission from Ichikawa Soft Laboratory Co., Ltd.
- The manufacturers, the cameras, and the software names that have been described in this manual are the trademarks or registered trademarks of each company.
- SILKYPIX®; It is a registered trademark of Ichikawa Soft Laboratory Co., Ltd.
- The re-distribution module that Microsoft Corporation owns the copyright is included.
The following browsers are recommended for viewing this manual.
Please note that the manual may not operate correctly even when used in a recommended environment depending on the settings of the OS and browser.
Please be understanding of this beforehand.- Windows: Internet Explorer 11, Microsoft Edge latest version, Google Chrome latest version, Mozilla Firefox latest version
- macOS: Safari latest version
