0. Overview and Introduction
0.1. Section Names
Main window
Various functions can be executed by clicking on icons in the toolbar. Icons also have the function of displaying status.(D) Status bar
Parameters controls comprises four parts.(F-1) Main control
The main functions are for selecting tastes prepared for each category of development parameters and for calling up sub-controls for adjusting parameters in detail.
Adjust exposure bias here.(F-2) Sub-control icon
This switches between displaying and not displaying sub-controls displayed as floating windows.(F-3) Tab page
Sub-controls for detailed adjustments in each category of the development parameters are displayed here.
The sub-controls displayed here can be changed through operations on the Main Control.(F-4) Control box
We recommend that you arrange sub-controls that you use frequently here. Please see “4.2. Sub-control” concerning sub-controls.
(G) Preview window
This window can be located outside of the main window and displayed as a floating window.(I) Section switching button
This button switches the contents of the main window according to the purpose of work.
Please see “0.2. Section” for information about section.
Floating window
0.1.2. Menu bar
File (F)
Open JPEG images for development processing as single files.Develop (D)
Close all developed images.Print (R)
Switches to the Print section and prints the selected images.Load development parameters (L)
Close selected images.Exit (X)
Close SILKYPIX.Plug-ins
Edit (E)
Rotate left selected image.
Tools (T)
With the Gray balance tool for underwater photo, you can designate parts of the photo you want expressed in gray (neutral colors), which automatically adjusts the white balance so that those parts are expressed in gray, as well as calculating the color depth and underwater color deviation.Spotting tools
Use spotting tools to correct images and remove spots.Crop tool
You can designate areas and make partial corrections to brightness, contrast, etc.Negative film inversion tool
Inverts the negative film image to a positive image in relation to the specified part of the preview display.Perspective correction tool
Correct the perspective by specifying horizontal and vertical on the preview display.Perspective correction tool (horizontal)
Correct the perspective by specifying a horizontal value on the preview display.Perspective correction tool (vertical)
Correct the perspective by specifying a vertical value on the preview display.
View (V)
Items related to Main Control and Sub-controls are found here.Select
Switches the main window to the Select section.Adjustment
Switches the main window to the Adjustments section.Print
Switches the main window to the Print section.Thumbnail mode
Highlight areas for modifying images with “Partial correction tool.”Display grid
Select images to be displayed from within images for processing.Display toolbar
Turn toolbar display on / off.Display status bar
Turn “Image Properties” sub-control display on / off.Navigator
Turn “Search in the thumbnail” sub-control display on / off.Sub-controls
Turn sub-controls display on / off.Display settings (D)
Parameters (P)
Development (D)
Settings (S)
Sort icon buttons and turn icon button display on / off in the toolbar.Imprint data for printing settings
Delete access history
Initialize sub-controls display location and status.Select skin
Select SILKYPIX skin.
Help (H)
Delete development parameters files for all images currently being processed.Product key registration test
Version information
Display SILKYPIX version information and customer’s license information.
0.1.3. Toolbar
Please see “9.4. Shortcut keys settings” for how to set keys.* The order of icon buttons in the toolbar and whether or not to display them can be freely customized.
The display location of the toolbar can also be changed.
Please see “9.6. Customize toolbar” for how to make the settings.* Depending on the selected section, the icons on the toolbar are shown or hidden.
In addition, the available functions vary from section to section.
Previous image
Move selected image to next image.Thumbnail mode
Adjust display settings for highlight warning, shadow warning, out of color gamut warning and soft proofing.Undo
Add one step in history to the status of the editing history for development parameters.Exposure bias tool
Adjust black level based on designated points in preview display.Negative film inversion tool
Correct the perspective by specifying horizontal and vertical on the preview display.Composite selected images
Composite the selected images and exports them to a file.Rotate left
Rotate right selected image.Develop mark
Mark selected image for development.Develop
Develop one selected image and save to file.Batch develop selected images
Perform batch develop for selected images.Batch develop marked images
Perform batch develop for marked images.Open with another application
Develop selected images and open with another application registered in advance.Batch development status
Turn “Batch Development Status” sub-control on / off.Environment settings
Make SILKYPIX settings such as File output settings, Display settings and Function settings.Search in the thumbnail
Search for and filter images in the thumbnail by file name, date, and so on.
There is also a section switch button (*1) on the right side of the toolbar to switch the contents of the main window according to the purpose of work.
Select
*1 If the main window is narrow in width, only the icon is displayed.
* Please see “0.2. Section” for information about section.
0.1.4. Information Box
Each Information Box is divided into an upper and lower part. The “Navigator” and “Histogram” can be located in the upper part of the box.
In addition, the “Folder”, “Parameters controls” and “Image properties” can be located in the lower part of the box.
0.1.5. Parameters Controls
You can locate multiple controls within the box, or combine each control and locate them on a tab page or in a control box.
You can change the location of a control are performed from the Context Menu, displayed when you click
on the upper right of the controls.
Icons for selecting category
Select sub-controls category displayed on tab page.Dropdown list for selecting taste
Initialize development parameters and automatically adjust images.Control for adjusting exposure bias
Adjust “exposure bias” and “exposure bias fine tune” parameters in the “Exposure / Luminance” category within development parameters. Select automatic exposure bias here.
Sub-controls for adjusting development parameters are displayed on the tab page by default, or as a floating window, with each category prepared separately. (*1)
Sub-controls can be located in the control box.
0.1.6.1. Category Selection Icons
Located in the Main Control part, the following sub-controls are displayed upon selecting the Category Selection Icon.
Furthermore, these sub-controls are located on the tab page by default.
If the development paramer on the sub-control has been modified, Icons will be colored like those to the right.
(A) Tastes/Parameters
Switch to “Tastes/Parameters” sub-control.
Tastes selected here are tastes for all categories of development parameters. There are two types of tastes, overall tastes and partial tastes.(B) Exposure / Luminance
Switch to “Exposure / Luminance” sub-control.
This category exists only in overall tastes, and there are no partial tastes.(C) White balance
Switch to “White balance” sub-control.
Tastes selected here are partial tastes in the “White balance” category.(D) Tone
Switch to “Tone” sub-control.
Tastes selected here are partial tastes in the “Tone” category.(E) Color
Switch to “Color” sub-control.
Tastes selected here are partial tastes in the “Color” category.(F) Sharpening
Switch to “Sharpening” sub-control.
Tastes selected here are partial tastes in the “Sharpening / Noise reduction” category.
“Sharpening” and “Noise reduction” exist as separate sub-controls, but they share the same development parameter.(G) Noise reduction
Switch to “Noise reduction” sub-control.
0.1.6.2. Sub-control icons
Sub-controls that can be selected from the sub-control icons at the bottom of the Parameters controls are as indicated below.
Controls displayed from the sub-control icons are displayed as a floating window by default.
White balance adjustment
This is the sub-control for adjusting the white balance according to feeling.Tone curve
This is the sub-control for minute tone adjustments with the tone curve.
It has a level bias function.Highlight controller
This is the sub-control that adjusts the tint and gradation of parts saturated by color.
It can also perform dynamic range adjustments.Fine color controller
This is the sub-control for performing hue / chroma / brightness adjustments for each color hue.Lens aberration controller
This is the sub-control for compensating for shading (when surrounding light quality is low), and distortion, as well as chromatic aberration.Rotation/Shift lens effect
This is the sub-control for rotating images and performing shift lens effect.Development settings
This is the sub-control that displays “Development settings”.
It is not a taste that can be set.Effects
This is the sub-control for adding various effects to images, such as portrait beautification and adding noise.Monochrome controller
You can make adjustments when making black and white images by using two types of settings: a “Color filter” to simulate effects such as adding the set color filter to a lens, and “Lightness” to adjust the lightness of specified hue.Underwater photo controller
You can make special adjustments for underwater photography, such as white balance dedicated to underwater photographs and color restoration to restore colors lost in the water.Spotting tools
Use spotting tools to correct images and remove spots.Partial correction tool
You can designate areas and make partial corrections to brightness, contrast, etc.Crop tool
Use the crop tool to crop an image in preview display.Editing history
This is the sub-control that displays editing history for development parameters, and allows you to return to past editing conditions or to display them on the preview window for comparison.
0.1.7. How to Locate Controls
A
icon is displayed to the upper right of most controls, such as Parameters controls and Sub-controls.
A context menu is displayed when you click on this menu, and you can change the location of controls from this menu.
0.1.8. How to Operate GUI
Slider control
This is a SILKYPIX JPEG Photography 10 standard GUI composed of slider bars, text boxes and buttons for changing numerical values.
Except for direct editing modes in text boxes, the concept of focus was not adopted for “SILKYPIX JPEG Photography 10”, so please use the mouse wheel to move the mouse cursor on controls for operations.
* Enable the mouse wheel operation on the control box to change parameters in the Function settings must be enabled.
Edit control
This is a SILKYPIX JPEG Photography 10 standard GUI composed of text boxes and buttons for changing numerical values.
Dropdown list
0.2. Section
The contents of the entire main window of the software can be switched to three modes depending on the purpose of work.
In this software, each mode is called a section.
The first time you start the software program, the select section is selected.
The next time you start up, it will start up with the section at the end selected.
However, if you exit with the Print section selected, the Select section is selected at startup.
The functions available in each section vary from section to section.
Unless otherwise noted, there are no differences between sections of the same function.
0.2.1. Select
The Select section is used to select photos that need adjustment from a large number of images.
Switch to the Select section by clicking the
Select button on the toolbar or choosing [View]-[Select] from the menu.
In the Select section, you can use the functions related to image selection, such as file operations, marks and rating operations, and filtering images for processing, but you cannot use the functions related to image adjustment.
For more information on the Select section, see “2.1. Select”.
0.2.2. Adjustment
The Adjustment section is used to make adjustments to the image.
In the Adjustment section, you can also export the adjustment results to a file.
Switch to the Adjustment section by clicking the
Adjustment button on the toolbar or choosing [View]-[Adjustment] from the menu.
Most operations related to adjusting and exporting images are based on operations in the Adjustments section.
0.2.3. Print
The Print section is used to print the selected images.
You can set the print settings while checking the print image on the main window.
Switch to the Print section by clicking the
Print button on the toolbar.
Alternatively, select [File(F)]-[Print(P)] or [View(V)]-[Print] from the menu.
See “8.5. Printing” for details on the functions and operations of the Print section.
0.3. What is SILKYPIX JPEG Photography?
“SILKYPIX JPEG Photography 10” has all of the features of the first choice photography software of professional photographers and enthusiasts “SILKYPIX Developer Studio Pro 10”except is supports only the JPEG file format.
SILKYPIX JPEG Photography 10 does something like an “inverse transformation” from a JPEG image to a virtual RAW data (*1) and then treats them same as RAW data internally. (The function is “SILKYPIX RAW Bridge.”)
Therefore, SILKYPIX JPEG Photography 10 does the color processing which is more correct than photo retouching software can be done.
*1 … RAW data is the unprocessed data recorded as digital light energy information that image sensors capture. Compared to normal JPEG files, RAW files are bigger in size because native information is recorded at the time the photograph was taken.
0.3.1. Basic Image Adjustment Items
Exposure bias
You can adjust parameters at the development process with SILKYPIX JPEG Photography 10 and obtain the same effect when using the function of the camera.
You can obtain results comparable to photographs taken with specifying the beforehand light source on your camera by adjusting parameters when you develop them.
You can also obtain results comparable to photographs taken using color temperature conversion filters by adjusting parameters when you develop them.* However, if you make adjustments to white balance on JPEG images, they will be adjustments relative to this color temperature = 6500K, color deviation = 3. (*1)
Sharpening / Noise reduction adjustments
You can emphasize the outline of a shot image, or change the noise reduction during the development process.* However, for the JPEG image, the default setting of the “Sharpening” sub-control and the “Noise reduction” sub-control has no effect.
Therefore, you have to relatively adjust “sharpening” or “noise reduction” from the original “JPEG” image, because it has already been processed in the camera or by software.Tone Adjustment
*1 With JPEG images, this is after white balance processing has been done on the camera, so unfortunately the color temperature at the time the photograph was taken cannot be set to standard reference.
Supposing there are JPEG images that have had perfect white balance adjustments, they cannot be distinguished, no matter what source of light these photographs were taken under.
For actual photographed JPEG images, the influence of the light source at the time it was taken will remain, but in either case the color temperature at the time it was taken cannot be ascertained, so the default white
This color temperature is the white point value for sRGB and Adobe RGB.
Whatever light source the JPEG images were taken under, they will be processed under the assumption of having been taken under a light source of 6500K.
0.4. Difference to Other Photo Retouching Software
The development process with SILKYPIX JPEG Photography 10 and image processing with a photo retouching software are similar.
However, there is a critical difference between them.
Therefore, we dare to use the word “development”.
Understanding of the difference helps you to use SILKYPIX JPEG Photography 10 to its fullest.
The important point is that this software always starts every image processing function based on the original JPEG data.
When you change parameters in image processing (for example, changing “Exposure bias”, “white balance” or “saturation”), the software always starts processing based on the original JPEG data.
Development parameters are recorded in separate files different from the original JPEG data.
The original JPEG data is not modified (non-degrading image processing).
The basic design of this software is to “not modify the original JPEG data files”.
If JPEG files recorded on a camera are processed with photo retouching software or digital camera editing software, there is a chance that the original image will be overwritten, but with this software the original data file is not modified. (*1)You can change parameters until you’re completely satisfied
With this software, image processing always takes place in the optimal order after reading the original JPEG data.
Development parameters are automatically read and updated for each image, and are managed in a file separate from the original JPEG data. (*2)
Development parameters are also concealed in JPEG images that saved developments.
If you have the developed JPEG images and the original JPEG data, the development parameters for the development results can be read and minute adjustments can be made from the previous adjustment results at any time.Perform efficient image adjustments.
*1 It is possible to rewrite rotation information tags, depending on the settings.
*2 Development parameters are automatically recorded in a “SILKYPIX_DS” sub-folder created within folders that contain the original JPEG images.
*3 Development parameters are buried within the Exif information in JPEG images that record development results.
They will not be buried if not recorded with Exif information.*4 “Spotting tools” information is not included in development parameters buried in JPEG images that record development results.
With SILKYPIX JPEG Photography 10, we have applied the technology to such processes that irregular images like Distortion Correction and, Digital Shift and implemented a completely continuous image processing in those processes.
