SILKYPIX JPEG Photography 10 SOFTWARE MANUAL
9. Option and Setting
9.1. File output settings
9.1.1. Taste
  1. Selecting a taste
  2. Registering a taste
9.1.2. JPEG settings
In this software, you can save a JPEG file format.
Settings for recording and saving in the JPEG format will be explained here.
  • (A) Quality
  • (B) Type
  • (C) Quality
    • [Culled color information]
9.1.3. Default folder to save
You can specify the default folder to save the developed JPEG files. This is a default setting for the “Save as” dialog and you can modify to any folder for saving every time.
9.1.4. JPEG options
When the development result is saved in the JPEG file, incident information is saved together, for which option is set on the Option for JPEG. This setting does not have any influences on the results of the picture. Only the incidental information recorded in the image is influenced.
  1. Resolution
    The recorded “resolution” in JPEG is defined here. The default setting is 300dpi.
  1. Record ICC profile
    You can specify whether to record the ICC profile which indicates color space into an output JPEG file. It is checked in the default.
    When you record the ICC profile, it is recorded using a method that conforms with the standards of JPEG.
  2. Discard SILKYPIX parameters and image information
    This setting allows you not to record the information into a JPEG file, which is the information about taking a photograph and the development parameter of SILKYPIX. This setting is not checked in the default.
    Please use this setting if you do not want to disclose the information about taking the photograph and developing with SILKYPIX JPEG Photography 10.
  3. Discard thumbnail
    This setting allows you not to record the thumbnail into a JPEG file, This setting is not checked in the default.
  4. Discard orientation tag
  5. Set ‘CustomRendered’ as ‘Custom’
  6. Capitalize extension
    This setting is a capitalize the extension of JPEG image files when you save the develop.
  7. Set date taken to file creation date
    This is a setting for creating / updating the date and time as a file attribute in JPEG image files that were recorded and saved from development results.
9.1.5. Output options
These are the setting how to develop to a JPEG file. These setting affect the developed image itself.
  1. Rotate and save images
9.1.5.2. Output color space
  2. sRGB color space
  3. AdobeRGB color space
When saving development results, the default name set as JPEG image file names is given.
By default, “%N” control character which means the base name of the original JPEG file is set.
    • %N : Basename of the JPEG file (“Basename” means a part of filename except the extension)
    • %L : Focal Length
    • %F : F Number
    • %T : Shutter Speed
    • %I : ISO Speed
    • %M : Date Time - Month
    • %D : Date Time - Day
    • %h : Date Time - Hour
    • %m : Date Time - Minute
    • %s : Date Time - Seconds
9.2. Display settings
* Please refer to “9.9.3. Select skin” concerning switching skins (= background image).
9.2.1. Color management
* This setting is only available on the Windows version.
The preview image cannot display accurate colors if it is a JPEG image recorded in an input color space other than sRGB and if the output color space is set to something other than sRGB when color management is disabled.
* In the macOS version, this automatically succeeds the monitor profile set on the macOS and displays the program.
Therefore, there is no “Color management” item in the macOS version.
Please refer to “10.2.4. Color management” for details.
9.2.1.1. Monitor profile
Please refer to “10.2.4.4. Color management on monitor displays” for details.
9.2.2. Thumbnail window
  1. Image width
  2. Sort thumbnails
9.2.3. Preview window
9.2.3.3. Grid Settings
9.2.3.4. Partial Correction Tool Settings
  • Brush overlay color
    This is a setting for overlay color displays shown when drawing / editing the Brush in the Partial Correction Tool.
  1. Stay in preview mode
  2. Change to thumbnail mode
  3. Change to combination mode
9.2.3.6. Background colors
9.2.4. Others
  • Enable smooth scrolling
9.3. Function settings
The menu command [Settings (S)]-[Function settings (U)] displays the “Function settings” dialog in which you can set a method of saving the rotation for JPEG, a brightness level of exposure bias tool and so forth.
9.3.1. Functions
9.3.1.1. When a JPEG image is rotated
When rotating the image of JPEG files, there are two ways to record the rotation information. You can specify whether or not to overwrite rotation information in the original file.
    Since the rotation information is overwritten in the original file, other software (*) besides SILKYPIX JPEG Photography 10 can recognize rotation information.
* The default value used to be 0.5(%) for both the shadow / highlight sides in SILKYPIX Developer Studio Pro 8 and earlier, but it has been changed to 0.1(%) in SILKYPIX JPEG Photography 10.
9.3.1.8. Tooltip
Set the tooltip display.
  1. Information button
  2. No information button
  3. Do not display tooltip
    Do not display the tooltip.
9.3.1.9. Open last accessed folder when starting
9.3.2. Operations
    If this setting is not checked, values will not be changed when the mouse wheel is operated on controls.
9.3.3. Performance
9.3.3.1. Cache settings
  • Restrictions
  • Standard (default)
    It’s a standard setting.
  • Maximum
    Maximize the use of Cache
  • Normal (default)
9.4. Shortcut keys settings
9.4.1. GUI Operation methods
  1. Function category
  2. List
  3. Software keyboard
  4. Initialize
  5. Export
  6. Import
9.4.3.1. Reserved keys
  • [F1]
  • [PageUp]
  • [PageDown]
  • [Home]
  • [End]
  • Ctrl+[A]
  • Ctrl+[C]
  • Ctrl+[V]
  • Ctrl+[+]
  • Ctrl+[-]
  • Alt+Ctrl+[0]
  • Shift+[Up Arrow]
  • Shift+[Down Arrow]
  • Shift+[Right Arrow]
  • Shift+[Left Arrow]
  • [Attention]
* “Default parameters” affect only RAW images. For JPEG images, “Default parameters” are predefined values and cannot be changed.
9.6. Customize toolbar
You can also select [Customize toolbar] from the context menu displayed by right-clicing on the toolbar.
  1. Current items
  2. Available items
  3. Add
  4. Remove
  5. Move up
  6. Move down
  7. Insert separator
  8. Reset to defaults
* This setting is saved for each size of the skin that can be selected in “9.9.3. Select skin”.
* The items available in this setting differ for each selected section.
In addition, this setting is saved for each section.
9.7. Imprint data settings
  1. Imprint data list
    • Maker data
    • User data
  2. Edit
    Edit selected data.
  3. Create new
    Create new data.
  4. Copy
  5. To upper
  6. To lower
  7. Hide / Show
  8. Delete
    Delete selected data.
  9. Rename
  10. Export all
  11. Export
  12. Import
9.7.1. Edit imprint data
  • Data name
  • Characters for imprinting
  • Image for imprinting
  • Base size of data
  1. Edited image display area
  2. Name
  3. Edit control
9.7.1.1. Layer settings
  1. Add layer
  2. Copy layer
    Copy selected layer.
  3. Delete layer
    Delete selected layer.
  4. List of layers
9.7.1.2. Character settings
  1. Standard point
  3. Size
    Set character size.
    When composition mode “Automatic size adjustment”, if the standard size of imprint data is changed to match the size of the image, the height will change at the same ratio.
    If “Composite by the fixed-size” or “Composite relative to paper” is being used in the composition mode, imprinting will be performed at the set size.
  4. Setting details
      • %L : Focal length
      • %F : F number
      • %T : Shutter speed
      • %I : ISO speed
      • %l : Lens
      • %c : Model
      • %n : Filename
      • %C : Comment
      • %t : Title
9.7.1.3. Image settings
  1. Standard point
  3. Size
  4. Selecting image
    Read an image.
9.7.1.4. Base size
  1. Base size
    Set this standard size.
    The composition mode for imprint data when printing and developing can be designated, but if “Composite by the fixed-size” or “Composite relative to paper” is being used in the composition mode, imprinting will be performed at the set size.
    When composition mode “Automatic size adjustment”, the ratio of image and character size will remain the same as the base size and the size will change to fit the paper and output size.
  2. Preview
9.8. Import and export settings
  • File output settings
  • Display settings
  • Function settings
  • Shortcut keys settings
9.8.1. Export
  1. Save file
  2. Settings to be exported
* When you import a setting file exported from SILKYPIX JPEG Photography 10 in a previous version, some settings are lost in a previous version.
9.8.2. Import
9.9. Options
9.9.1. Delete access history
9.9.2. Initialize window positions and display states
9.9.3. Select skin
This new skin is only visible after restarting SILKYPIX JPEG Photography 10. To display with the new skin, please close this software once and re-execute it.
9.9.3.1. Large-sized skin
9.9.3.2. Skins for high-resolution monitors
9.10. Troubleshooting settings
9.10.1. Initialize user configuration files
9.10.2. Product key registration test
If it is determined that you cannot perform online registration of your product key, enter your “Serial number” and “Product key” in the “Product key registration” dialog and register offline by clicking on the “Offline registration” button.
9.10.3. Troubleshooting settings
9.10.3.1. Prohibit parallel processing during developing
Furthermore, if you want to specify more enhanced setting for limiting temperature rise, refer to ‘9.10.3.2. Develop slowly’.
      SILKYPIX JPEG Photography 10 runs a CPU with high efficiency. Because of this, we say that a temperature of CPU gets higher than a case of running other software.
9.10.3.3. Delete manufacturer name from Exif information
9.10.3.4. Restrict simultaneous file access
