This will explain development processing of JPEG images, and how to save the results as JPEG image files.
| Format | For processing | Processing format | Preview display | Other features |
| Develop | One image | Real time processing / batch processing | Yes | Possible to set details for each image |
| Batch develop | Multiple images | Batch processing | No | Possible to efficiently batch process |
[Processing format]
Processing status is displayed in a progress bar.Batch processing
In addition, there is a “Composite selected images” function that composite images of multiple selections and saves them as a single DNG or TIFF images file.
5.1. Develop
When you click the
icon on the “Development settings” sub-control or the toolbar, the “Save as” dialog is displayed.
Saved file
You can designate the file folder, file name and type of file for saving the development results.Settings
You can make settings for develop while looking at the preview display of the development results.Develop tastes
You can switch to develop settings from these tastes.Batch develop
Registered jobs are processed as batch development. When job registration is complete, develop is closed, whether or not development processing has been completed and you can go to the next operation.Develop
5.1.1. Saved File
You can only select a JPEG image (*.jpg) as the type of file.
Please make detailed settings related to JPEG images on the “Settings” page.
5.1.2. Settings
5.1.2.1. Develop Taste
5.1.2.2. Basic settings
Image size to save
There are two ways to make designations, as follows.a) Designate any desired pixel size
Click the initialize button to return to default values.b) Fit to designated size
File output settings
5.1.2.3. Enhanced settings
5.1.2.4. Preview
Before saving an image, you can check it with the preview, which reflects the effect of the “unsharp mask” and “JPGE compression”.
When you adjust the setting value for the “unsharp mask” or the JPEG image, the preview is automatically refreshed.
It takes a time to complete the development of the entire preview image.
But when part of the image is displayed, only the part is developed, shortening the time for development.
5.2. Batch develop
Batch develop selected images
Select [Development (D)]-[Batch develop selected images] from the menu, or click on the icon in the toolbar to begin processing.
The toolbar icons change based on the status of selected images.
The
(Batch develop selected images) will be displayed only when multiple images are selected.Batch develop marked images
Select [Development (D)]-[Batch develop marked images (B)] from the menu, or click on the icon in the toolbar to begin processing.
The
(Batch develop marked images) will be displayed only when one image is selected.Immediately batch develop selected images
This function is also assigned to the [F5] key by default.Register from “Develop” to Batch develop
Select [Development (D)]-[Develop (D)] from the menu, or click on the icon in the toolbar to begin processing.
The number of remaining jobs is also displayed on the batch development status icon on the right side of the toolbar.
5.2.1. Batch Develop Tastes
5.2.2. Basic settings
You can designate the type of file to be saved (only JPEG), pixel size of the image to be saved and development result save settings here.
Image size to save
The following three methods are for designating.a) Same size (100%)
The cropping size is not designated, even if the output size is designated in the Crop tool.b) Resize to cropped size
If cropping is not performed and if the output size is not designated in the Crop tool, a same size (100%) is recorded.c) Fit to designated size
5.2.3. Enhanced Settings
5.2.4. Other settings
Folder to save
You can select the folder to save a file using the following three ways.Same folder as original JPEG images
You can save a developed image in the same folder as the original JPEG image is stored.Subfolder in original JPEG image folder
You can create a sub-folder under the same folder as the original JPEG image is stored.Specify folder
When file names are conflicted
Please be extremely careful.
You can select one of the following four types of measures.Rename automatically
A different file name is automatically created and given to the file as RAW data.Ask for confirmation
Please decide the file name.Overwrite
When the file name exists already, SILKYPIX JPEG Photography 10 overwrites the existing file automatically.Skip
When the file name exists already, SILKYPIX JPEG Photography 10 skips saving the file.
The default naming conventions use the base name of the JPEG file for image processing.
Don’t remove ‘Develop mark’ after develop
In order to check the batch development status, select [View (V)]-[Batch development status] from the menu or click on
in the toolbar to make the “Batch development status” sub-control appear.
5.2.5.1. Waiting
You can delete a selected job with the
icon.
5.2.5.2. Finished
icon.
By selecting “Open with Explorer (O)” after you select a job, you can open the developed and saved JPEG image file in Explorer.
All batch development will be halted by clicking on
on the bottom right.
Click on
when paused to restart batch development.
5.3.1. Basic Settings
5.3.1.1. File type for saving
From the drop down list, you can only select JPEG file. When you want to set this in detail, use the “File output settings” dialog as described below.
5.3.1.2. File output settings
You can also set JPEG saving formats here.
You can make detailed settings for “JPEG” here.
Items that can be set here are the same as the items that can be set with “Setting details”. Please see “9.1.2. JPEG settings” for details.
5.3.1.3. Image size to save
- [Adjust orientation of the above rectangle to the target aspect ratio]
5.3.2. Enhanced settings
5.3.2.1. Imprint data
Imprint data
Select which data for imprint data you will use.Edit data
Please refer to “9.7.1. Edit imprint data” for details.Configure list
Please refer to “9.7. Imprint data settings” for details.Title
Set the title.
Use this if you want to temporarily set characters without changing the data for imprint data. The character string entered here is replaced when the control character “%t” of the character string for the data for imprint data is set. Multiple lines can be set.Composition mode
For “Develop”, select an appropriate composition mode while looking at the preview display.Automatic size adjustment
Select this setting when imprinting to file output.Composite by the fixed-size
5.3.2.2. Unsharp mask
The other hand, the “unsharp mask filter” should be used for a certain purpose and the output type. For example, when you want to reduce an image for using on a website, you can use the unsharp mask to make up for the sharpness of the image, which will be lost by the image reduction. Or when you want to prepare an image for printing, you can use the unsharp mask to increase image sharpness, avoiding blurred prints.
Please refer to ‘10.1.5. Proper Use of Sharp in Development Parameters and Unsharp Mask when Developing / Printing’ for more details.
5.3.2.2.1. Amount
5.3.2.2.2. Radius
5.3.2.2.3. Threshold
5.4. Composite selected images
“Composite selected images” is a function to composite selected images and save them as JPEG-format files.
“Composite selected images” dialog appears by clicking the
icon on the toolbar or by right-clicking the selected image on the thumbnail and selecting “Composite selected images” from the context menu that appears.
* This function is available only when multiple images are selected.
By selecting Composite method and clicking [Composite], you can composite the selected images.
As a condition for compositing, the pixel sizes of the output area of the selected image must all be the same.
If the cropping area is set, it is determined by the size of the pixels after cropping.
5.4.1. Composite method
Select Composite method as desired from the following modes:
Multiple exposure
Composited images are handled equally and result in an image similar to a multiple exposure shot taken with a camera.
If you composite two or more shots of the same scene, you can achieve much more sophistication and high dynamic range photography than normal Noise reduction.Multiple exposure (night view)
Images are composited with a focus on noise reduction, saturation, and black level for night views.
This mode allows you to create a long-exposure, beautiful night scene from multiple photos taken with hand-held shooting.
You can control the synthesis of dark areas with the optional Black level correction.
The stronger Black level correction, the less dark areas are raised or dust appears, but the lighter areas are darkened.- Option
- Black level correction: None
- Black level correction: Weak
- Black level correction: Medium (default)
- Black level correction: Strong
- Option
Lighten composite
Selected images are compared and composited giving priority to the brighter parts of each image.
For example, if you composited an image of fireworks, you can make a photograph of large fireworks.Moving object removal
Multiple images taken in the same shooting situation are composited without moving objects.
For example, if you combine images of intersections where many people are walking, you can create a photograph of intersections where no one is walking.
You can control the removal intensity with Moving object removal options.
The stronger the removal intensity, the easier it is to remove the moving object, but the more unnatural dust is likely to appear.- Option
- Moving object removal: Weak
- Moving object removal: Medium (default)
- Option
Stroboscopic motion
Multiple images taken in the same shooting situation are composited with moving objects.
You can create a sequence photograph that expresses motion by continuously emitting strobes in the dark.
You can control the strength of the composite with “Composite strength” options.
The strongerthe intensity, the more clearly the moving object is composite, but dust will be more likely to appear.- Option
- Composite strength: Weak
- Composite strength: Medium (default)
- Option
Depth of field composite
An image that is in focus over a wide area can be created by compositing images with different focus points from near to far.
5.4.1.1. Correct for misalignment during hand-held shooting
When this checkbox is selected, alignment process is performed for images in witch the position of the subject has shifted during hand-held shooting.
This function is based on the representative image and transforms other selected images to match the representative image as much as possible.
Depending on the image, the correction may not be performed successfully.
When correction cannot be performed, “Failed to correct misalignment. Images will be composited without performing alignment.” is displayed below the preview display, and compositing without correction is performed regardless of whether the checkbox is selected.
