0. Overview and Introduction
0.1. Section Names
Main window
Various functions can be executed by clicking on the icons in the toolbar at the top and bottom. The icons also display the status.(D) Status bar
Parameters controls comprise two parts.(F-1) Main control
The main functions are for selecting tastes prepared for each category of development parameters and for calling up sub-controls for adjusting parameters in detail.(F-2) Control box
You can switch between “Quick” and “Advanced.”
Please see “4.2. Sub-control” concerning sub-controls.
(G) Preview window
This window can be located outside of the main window and displayed as a floating window.(I) Section switching button
This button switches the contents of the main window according to the purpose of work.
Please see “0.2. Section” for information about section.
Floating window
0.1.2. Menu bar
File (F)
Open RAW data and JPEG/TIFF/HEIF images for development processing as single files.Develop (D)
Close all developed images.Import from media
Copy images from removable media such as SD cards.Print (R)
Switches to the Print section and prints the selected images.Load development parameters (L)
Close selected images.Composite selected images
Composite the selected images and exports them to a file.Exit (X)
Close SILKYPIX.Plug-ins
Edit (E)
Rotate left selected image.
Tools (T)
With the Gray balance tool for underwater photo, you can designate parts of the photo you want expressed in gray (neutral colors), which automatically adjusts the white balance so that those parts are expressed in gray, as well as calculating the color depth and underwater color deviation.Auto area specification tool
Specifies the area for calculating the three auto white balance settings: Auto (Absolute), Auto (Natural), and Auto (Underwater).Spotting tools
Use spotting tools to correct images and remove spots.Retouch brush tool
Use the brush to specify unwanted objects in the image, and copy any range in the image to it.Crop tool
You can designate areas and make partial corrections to brightness, contrast, etc.Negative film inversion tool
Inverts the negative film image to a positive image in relation to the specified part of the preview display.Perspective correction tool
Correct the perspective by specifying horizontal and vertical on the preview display.Perspective correction tool (horizontal)
Correct the perspective by specifying a horizontal value on the preview display.Perspective correction tool (vertical)
Correct the perspective by specifying a vertical value on the preview display.
View (V)
Items related to Main Control and Sub-controls are found here.Select
Switches the main window to the Select section.Adjustment
Switches the main window to the Adjustments section.Print
Switches the main window to the Print section.Thumbnail mode
Highlight areas for modifying images with “Partial correction tool”.Emphasize retouch brush areas
Highlight areas for modifying images with “Retouch brush tool”.Display grid
Select images to be displayed from within images for processing.Display top toolbar
Turn top toolbar display on / off.Display bottom toolbar
Turn bottom toolbar display on / off.Display status bar
Turn “Image Properties” sub-control display on / off.Editing history
Turn “Editing history sub-control display on / off.Tastes/Parameters
Turn “Tastes/Parameters sub-control display on / off.Navigator
Turn “Search in the thumbnail” sub-control display on / off.Filter
Turn “Filter” sub-control display on / off.Sub-controls
Indicates the display or hidden state of the sub-controls.Display settings (D)
Parameters (P)
Development (D)
Settings (S)
Sort icon buttons and turn icon button display on / off in the toolbar.Select skin
Select SILKYPIX skin.Imprint data for printing settings
Delete access history
Initialize sub-controls display location and status.
Help (H)
Delete development parameters files for all images currently being processed.Delete data file for the lens profile
Delete data files prepared for SILKYPIX to use the lens profile.Product key registration test
Version information
Display SILKYPIX version information and customer’s license information.Check for software updates
Check for any new version of the program.
0.1.3. Toolbar
Please see “9.4. Shortcut keys settings” for how to set keys.* The order of icon buttons in the center of the top toolbar and whether or not to display them can be freely customized.
Please see “9.6. Customize toolbar” for how to make the settings.* Depending on the selected section, the icons on the toolbar are shown or hidden.
In addition, the available functions vary from section to section.
0.1.3.1. Top toolbar
0.1.3.1.1. Left side
On the left side of the top toolbar, buttons mainly related to file input/output operations and edit history operations are placed.
Import
Copy images from removable media such as SD cards.Develop
Develop and save the selected or marked images to a file.Composite
Composite the selected images and exports them to a file.Another app
Develop selected images and open with another application registered in advance.Undo
Add one step in history to the status of the editing history for development parameters.
0.1.3.1.2. Center
In the center of the top toolbar, tool buttons mainly for editing images by operating on the preview image are placed.
Crop tool
Set the crop area of the image on the preview display.Rotation tool
Correct the tilt of the image on the preview display.Perspective correction tool
Correct the perspective by specifying horizontal and vertical on the preview display.Exposure bias tool
Adjust black level based on designated points in preview display.Skin color tool
Automatically adjust exposure and white balance based on the skin tone of the area specified on the preview display.Chromatic aberration tool
Automatically reduce chromatic aberration by specifying areas with significant color fringing on the preview display.Gray balance tool for underwater photo
Automatically adjust the white balance so that the specified area on the preview display, which you want to appear gray (achromatic), becomes gray.Negative film inversion tool
Inverts the negative film image to a positive image in relation to the specified part of the preview display.Spotting tools
Remove dust spots in the image or correct red-eye.Retouch brush tool
Use a brush to specify and remove unwanted objects in the image on the preview display.Partial correction tool
Specify the area you want to correct on the preview display, and partially adjust brightness, contrast, and other aspects within that area.
0.1.3.1.3. Right side
There is also a section switch button (*1) on the right side of the top toolbar to switch the contents of the main window according to the purpose of work.
Select
* Please see “0.2. Section” for information about section.
0.1.3.2. Bottom toolbar
0.1.3.2.1. Left side
On the left side of the bottom toolbar, buttons mainly related to the display and operation of the preview and thumbnails are placed.
Thumbnail mode
Adjust display settings for highlight warning, shadow warning, out of color gamut warning and soft proofing.Rotate left
Rotate right selected image.
0.1.3.2.2. Center
In the center of the bottom toolbar, buttons for setting marks and ratings for the selected images are placed.
* Please see “3.4. Operations for selected images” for details.
0.1.3.2.3. Right side
On the right side of the bottom toolbar, buttons for searching and filtering images within thumbnails are placed.
Search for and filter images in the thumbnail by file name, date, and so on.Filter
Specify conditions such as file information and shooting information, and select a value to narrow down the display targets for images in thumbnails.
0.1.4. Information Box
Each Information Box is divided into an upper and lower part. The “Navigator” and “Histogram” can be located in the upper part of the box.
In addition, the “Folder”, “Parameters controls”, “Image properties”, “Editing history” and “Tastes/Parameters” can be located in the lower part of the box.
0.1.5. Parameters Controls
Multiple controls are placed within the box.
The arrangement of controls can be changed through the context menu that appears when you right-click on the title of the control.
Dropdown list for selecting taste
Initialize development parameters and automatically adjust images.Quick/Advanced toggle button
Switch between controls within the control box.
The sub-controls for adjusting development parameters are initially displayed as “Quick” or “Advanced” control boxes or floating windows within the parameter controls, and are individually provided for each category. (*1)
0.1.6.1. Quick
In “Quick”, the basic adjustment controls that consolidate frequently used parameters are displayed.
For adjustable parameters, please refer to “4.1.4.1. Quick”.
0.1.6.2. Advanced
In “Advanced”, sub-controls for all parameters are displayed in a collapsed state.
For the sub-controls placed in “Advanced”, please refer to “4.1.4.2. Advanced”.
Clicking on the title expands and displays the sub-control. (*1)
Additionally, the icon in the title of the edited sub-control will be highlighted in color. (*2)
*1 Only one sub-control can be expanded at a time within “Advanced.”
If a sub-control is already expanded, it will be automatically collapsed.*2 Since “Sharpening” and “Noise Reduction” share the same development parameter category, editing either one will highlight the icons for both.
Additionally, the “Water Depth” and “Color Deflection (Underwater)” of the Underwater Photo Controller belong to the White Balance category, so the White Balance icon will be highlighted.
When the placement of sub-controls is changed to “Floating Window” or “Control Palette 1-4”, they move out of the control box in “Advanced”.
When the floating window or control palette is closed, the sub-controls are displayed again in the control box in “Advanced”.
0.1.7. How to Locate Controls
By right-clicking on the title of most controls, such as parameter controls or sub-controls, a context menu is displayed, allowing you to change the placement of the controls from the menu.
0.1.7.1. Make it a floating window
By clicking the
icon in the upper right corner of a sub-control placed in the control box or control palette, you can switch to a floating window with a single click.
0.1.8. How to Operate GUI
Slider control
This is a SILKYPIX Developer Studio Pro12 standard GUI composed of slider bars, text boxes and buttons for changing numerical values.
Except for direct editing modes in text boxes, the concept of focus was not adopted for “SILKYPIX Developer Studio Pro12”, so please use the mouse wheel to move the mouse cursor on controls for operations.
* When the “Enable the mouse wheel operation on the control box to change parameters” option in the Function settings is disabled, it will work by holding the [Ctrl] key while operating the mouse wheel.
Edit control
This is a SILKYPIX Developer Studio Pro12 standard GUI composed of text boxes and buttons for changing numerical values.
Dropdown list
0.2. Section
The contents of the entire main window of the software can be switched to three modes depending on the purpose of work.
In this software, each mode is called a section.
The first time you start the software program, the select section is selected.
The next time you start up, it will start up with the section at the end selected.
However, if you exit with the Print section selected, the Select section is selected at startup.
The functions available in each section vary from section to section.
Unless otherwise noted, there are no differences between sections of the same function.
0.2.1. Select
The Select section is used to select photos that need adjustment from a large number of images.
By displaying screennail and thumbnail images included in the image data, high-speed display and fast switching are realized.
Switch to the Select section by clicking the
Select button on the top toolbar or choosing [View]-[Select] from the menu.
In the Select section, you can use the functions related to image selection, such as file operations, marks and rating operations, and filtering images for processing, but you cannot use the functions related to image adjustment.
For more information on the Select section, see “2.1. Select”.
0.2.2. Adjustment
The Adjustment section is used to make adjustments to the image.
In the Adjustment section, you can also export the adjustment results to a file.
Switch to the Adjustment section by clicking the
Adjustment button on the top toolbar or choosing [View]-[Adjustment] from the menu.
Most operations related to adjusting and exporting images are based on operations in the Adjustments section.
0.2.3. Print
The Print section is used to print the selected images.
You can set the print settings while checking the print image on the main window.
Switch to the Print section by clicking the
Print button on the top toolbar.
Alternatively, select [File(F)]-[Print(P)] or [View(V)]-[Print] from the menu.
See “8.5. Printing” for details on the functions and operations of the Print section.
0.3. What is SILKYPIX?
This SILKYPIX software generates images by processing RAW data recorded by the digital camera. (*1)
This process of generating an image by processing RAW data is called “development”.
RAW data is the unprocessed data recorded as digital light energy information that image sensors capture. Compared to normal JPEG files, RAW files are bigger in size because native information is recorded at the time the photograph was taken.
When photographs are taken in RAW e.g. when photographs are saved as RAW data, you will be able to perform more varied image processing from the unprocessed light energy information even after taking the photograph.
The role of SILKYPIX is to get the most out of the photographic merits of RAW and to draw out as much image information as possible when reproducing scenes shot in RAW data. SILKYPIX was developed to make this a reality.
*1 … JPEG/TIFF/HEIF files can be developed. For more details, please refer to ‘2.6. How to Handle JPEG/TIFF/HEIF Image’.
0.3.1. Basic Image Adjustment Items
Exposure bias
You can adjust parameters at the development process with SILKYPIX Developer Studio Pro12 and obtain the same effect when using the function of the camera.
You can obtain results comparable to photographs taken with appropriate white balance settings on your camera by adjusting parameters when you develop them.
You can also obtain results comparable to photographs taken using color temperature conversion filters by adjusting parameters when you develop them.Sharpening / Noise reduction adjustments
You can emphasize the outline of a shot image, or change the noise reduction during the development process.Tone Adjustment
0.3.2. Features of SILKYPIX
When you store image data as RAW data and use this software to develop them, you don’t have to worry much about adjustments during taking the picture because you can do most corrections at the development process stage.
The merits of recording and saving to RAW data compared with saving in JPEG / TIFF are that information is not processed and the amount of information recorded is much richer.
It is also possible to readjust photographs recorded and saved as JPEG / TIFF / HEIF with this software.
However, compared to RAW data, there is less information recorded because JPEG / TIFF / HEIF images convert to a special color space (sRGB, Adobe RGB, etc.) and color gradation converts to 8bit = 256 steps.
Therefore, if you readjust photographs saved as JPEG / TIFF / HEIF, the breadth of adjustments are narrowed and deterioration of the image from the adjustments becomes greater.
In order to adjust images while maintaining high image quality, it is necessary to save the RAW data when taking the photograph.
By saving to RAW data and developing with this software, you will be able to obtain very similar results when developing after taking the photograph, as when color and image quality are adjusted at the time the photograph was taken.
SILKYPIX greatly shortens the time spent shooting and increases the chance of capturing that important “moment” on the camera.
In addition, with the adoption of a high development algorithm, SILKYPIX has the following features.
High resolution, High resolving power
Although it is generally considered that resolution is decided by the type of lens and the number of pixels of the image sensor, a key factor of actual image resolution is the demosaic process during development procedure.
When you select RAW data to record images and use SILKYPIX Developer Studio Pro12 to develop them, you can obtain higher quality pictures than the JPEG image which the camera records in taking a photograph.Advanced color separation
When photographing with a digital camera, the color boundary in high saturation area is lost and becomes white outline, which is a specific phenomena of digital cameras.
This effect called digital haloing is caused by the white outline through the phenomena that occurs when color resolution is low compared to excessive brightness.
We have therefore created a completely new demosaicing logic and embedded it into the software in order to provide advanced color resolution. This logic allows delicate and advanced color resolution.Less false color
Most of digital cameras now have sensors with a structure called Bayer array.
The R, G, and B sensor elements are allocated in order of Bayer array flatly. Each sensor can only capture one of the R, B or G, so false color appears on the edge of picture or area including delicate pattern.
The software reduces this false colors highly effectively with advanced pixel value forecast logic.
Fundamentally, high resolution, high separation capability, and false color reduction are not realized at the same time logically. High resolution causes increased false color phenomenon, and a trail of false color reduction results in low resolution.
However, the software efficiently enables the realization of these processes simultaneously to create natural pictures and colors.Color noise reduction at high sensitive photography
When photographing in high sensitivity mode for night photography or in a dark place, noise of the image sensor generates color noise spots on the image, which is specific to digital cameras.
These color noise spots appearing irregularly on the picture are very unpleasant to the eyes, and supposedly many photographers avoid high sensitive photography because of this phenomenon.
The software provides a function for reducing the color noise that surprisingly creates clean pictures for high sensitive photography.
With this software, you can select a wide variety of photographic methods and objects to create a new photograph.Hue control for highlight area
The software has the function to reduce color reverse or overexposure (bleached-out looking) in the highlight area.
For example, when taking a picture of a person, if you increase a development gain to make a skin color white, color shift phenomenon occurs and highlight boundary area often becomes yellow.
The Highlight controller of the software enables color control in over exposed area and creates fine color adjustment in these highlight areas.Real color reproducibility with high linearity
In order to create accurate colors with various types of light sources, we have embedded our unique color matching logic based on multiple color matching data acquired in many test pictures.
Many types of light source with various spectral distributions, such as sunlight (natural light), fluorescent light, tungsten filament lamp, glow of sunset, electric flash and combination of them are supported, which realizes accurate color reproducibility.
Based on this color reproduction, you can utilize “3-dimensional color mapping methods”, which converts colors into 3-dimentional data to create (Memory color) expressing similar colors with the colors in a human’s memory, (Portrait color), expressing highlights of the skin, and Film taste expressing colors in a positive (Film color)“. You can use these color modes according to its utilization or picture image.
Also, ‘4.10. Fine Color Controller’ can change the precise color and to control the delicate color.Highlight reproduction control by the “dynamic range compression”
The “dynamic range” control function allows you to make the best use of RAW’s ability, which has enough “dynamic range” and records whiter energy than the white point.
You can obtain the smooth gradation in highlight area similar to film.
0.4. Difference to Other Photo Retouching Software
RAW development process with SILKYPIX Developer Studio Pro12 and image processing with a photo retouching software are similar.
While various types of photo retouching software that support RAW data are increasingly available in the market, there is a critical difference between them.
Understanding of the difference helps you to use SILKYPIX Developer Studio Pro12 to its fullest.
The important point is that this software always starts every image processing function based on RAW data.
When you change parameters in image processing (for example, changing “Exposure bias”, “white balance” or “saturation”), the software always starts processing based on RAW data.
Development parameters are recorded in separate files different from RAW data.
RAW data is not modified (non-degrading image processing).
The basic design of this software is to “not modify RAW data files”.
If JPEG files recorded on a camera are processed with photo retouching software or digital camera editing software, there is a chance that the original image will be overwritten, but with this software the original data file is not modified. (*1)You can change parameters until you’re completely satisfied
With this software, image processing always takes place in the optimal order after reading the RAW data.
Development parameters are automatically read and updated for each image, and are managed in a file separate from the RAW data. (*2)
Development parameters are also concealed in JPEG / TIFF images that saved developments.
If you have the developed JPEG / TIFF images and the original RAW data, the development parameters for the development results can be read and minute adjustments can be made from the previous adjustment results at any time.Perform efficient image adjustments.
*1 It is possible to rewrite rotation information tags, depending on the settings, on JPEG / TIFF / DNG images.
*2 Development parameters are automatically recorded in a “SILKYPIX_DS” sub-folder created within folders that contain RAW data for editing and JPEG / TIFF / HEIF / DNG images.
*3 Development parameters are buried within the Exif information in JPEG / TIFF images that record development results.
They will not be buried if not recorded with Exif information.*4 Some information, such as Spotting tools, Partial correction tool, and Retouch brush tool, are not included in development parameters buried in JPEG / TIFF images that record development results.
With SILKYPIX Developer Studio Pro12, we have applied the technology to such processes that irregular images like Distortion Correction and, Digital Shift and implemented a completely continuous image processing in those processes.
